I'm getting ready to winterize the boat until Spring; got the time now. Just wondered what the general rules are?
1. Should I run the motor (100HP Evinrude) to to empty the carbs to keep the gaskets; float; etc. dry; or leave gas in motor and risk the carbs getting plugged up with varnish?
2. Have 20 gallons of gas in tank. Use the Stabil and leave alone; or drain a risk moisture build up in the tank?
3. I have a 12vVDC power supply that charges at 500ma. Will this work without overcharging the battey?
Any thoughts or suggestions?
