Hey guys, I'm doing a light restore on an '85 Ranger bass boat. I've read that the color can be brought back to life by wet sanding the gelcoat then compounding, polishing, and waxing. I started on it today and I'm a little disappointed. The surface is smoother, but there's not really any more color than before. I want to make sure I'm doing it right. Here's what I've done thus far:
1. Washed the boat
2. Wet sanded a small area with an "extra fine" sponge-type sanding pad
3. Wet sanded same area with 1000 grit sandpaper
4. Applied Meguiars Ultimate Compound with an orbital buffer (foam) - wiped clean by hand
5. Applied Meguiars Ultimate Polish with orbital buffer (wool) - wiped clean by hand
6. Applied 100% carnuba wax by hand - removed with orbital buffer (terry)
So after all that the area is smoother, but that's about it. When I wet sanded I saw grayish stuff coming off that I assume is the gelcoat. Do I need to go more coarse, or is the sandpaper just to knock down the heavy stuff? I read more and realized that most people say to use a rotary buffer. I'll get one of these tomorrow. Can I expect better results? Do I need to do anything else different?
The boat is red with a silver flake. The initial sanding looked like it was just going to highlight the flake. I want to get back to the original deep red. Tied to upload a photo, but cant. Check the link below.
Ranger Gelcoat
Thanks!!!
1. Washed the boat
Ranger Gelcoat
Thanks!!!
