i have a 5.7l gmc with a omc 800. rebuilt engine installed in june, running good all summer, oil pressure good, temp 160, lots of power. i was out two weeks ago everything was fine, flushed the engine on the muffs parked it. today i tried to start it, would not fire so i pulled the plugs and all 8 are wet. turned it over with plugs out some water blowing out of cyls. were do i start?<br />should i install new plugs and try to start it? <br />could it be the exhaust manifolds or riser, or flappers. oil in crankcase looks good no signs of water.
