Hey Guys,
I started my project of iupdating my 18 foot starcraft holiday. After cleaning it out and removing the gas tank I noticed I had several wet spots on the wood transom. The area by the motor mounts look good but it appears that the spashwell drain holes were pluged (previous owner put the output hose from the bilge pump through it). I am wondering now since I will be recarpeting and adding a casting deck in the rear of the boat should I redo the transom as well. Also do you think this would be a good project for seacast.
