What 4.3 rebuild kit
Shawn and lydia
I have an omc 4.3, model 432 acpdma. Looking for a engine rebuild kit, there are so many different part numbers for that engine. Engine is a 1994, any direction here would be much appreciated
Ayuh,.... Welcome Aboard,.... Rebuildin' a motor involves machine work, I suggest ya find yerself the Machinist yer gonna work with, 'n he will tell ya what parts ya need,....
Buyin' parts before hand leads to parts ya can't use, 'n don't need,.....
Welcome aboard Shawn
As bondo pointed out, take your motor to the machine shop you will use. You may only need a few hundred dollars in parts and labor, or a few thousand.
Only way to know is to tear down the motor and inspect everything, then order parts.
