juicebronco
- Jun 17, 2011
- 67
So I had a piston rod go, and in the process took out the oil pan, block, and cam. I replaced the engine with one I got from a donor boat. I've disassembled the old engine, and was trying to figure out everything I should keep.
List I know I should keep,
-Manifolds
-Exhast riser
-Heat exchanger
-Timing cover
-flywheel
-coupler
-Head
-I'm sure there is more I kept can't think of at the moment.
Is there any reason to keep pistons, rocker arms, crank shaft?
Just looking for input. Then I need to figure what I should try and hold on to, and what I should just try and sell.
-Manifolds
-Exhast riser
-Heat exchanger
-Timing cover
-flywheel
-coupler
-Head
