let's talk about having a bad day.Went to gas station to fill up fuel tank gave my uncle the credit card to fill my tank while i went across the street to get some bags of ice at the deli.I come back get on the boat to put ice in the fishbox and i could not beleive what i was seeing.My uncle pumped 40 gallons into my rod holder!!!!!!!!!!.To make a long story short the gas station attendant thought it would be wise to call the local fire departement.When they arrived they carefully moved my car and trailer away from the station and with hand pumps removed nothing close to 40 gallons.I thanked the firemen and drove home knowing that i have over 20 gallons of high octane splashing around in the hull.At my driveway tilted the bow up using jack stands under the trailer pulled the drain plug and filled 2 five gallon buckets.Another thing i forgot to mention is that the night before i had bought a new battery and while charging it i did not hook up the terminals.If battery terminals were installed and the bilge pump kicked on would there be a possibility of explosion? Another question is if there is any gas trapped in the hull would it weaken the fiberglass? Also if the foam absorbs the fuel would it eventually evaporate? Thanks in advance for any info. <br />Has anyone experienced this situation or am i the only one>>>>>>>>
