what and where excactly is a coupler
potatoe
can somone tell me what they mean by coupler? getting different answers.. thanks
bruceb58
Re: what and where excactly is a coupler
Mounted on the flywheel and it is splined. The driveshat that has your u-joints on it engages into it.
potatoe
thanks for the info , somone else here doesnt know what there talking about.
bruceb58
Well...I am correct assuming you have either a Mercruiser, newer Volvo or OMC Cobra. What do you have?
HT32BSX115
Since you now know what and where it is....you should probably also know that if yours is failed, you will have to remove the drive and remove the engine (in that order) to replace it.
If you want to do it yourself, at the minimum, get an OEM service manual and an alignment tool.
Cheers,
Rick
