What are good sealers for wood and best way to prep?
Gradywhite3535
I have a few wood assecories on the boat that needs to be refinished. Should I just sand it with 180 sandpaper then 150? Then shoukd i use a sealer or teak? How do you guys restore wood accessories? What is a good way to finish it to make-a-nice?
tpenfield
Re: What are good sealers for wood and best way to prep?
Teak oil, if it is teak . . .
or
Polyurethane
or
Epoxy
The problem with teak oil is that it needs constant re-application. Polyurethane will get you several years or more depending on sun exposure. Epoxy should get you a bit more longevity.
I had to do a fair amount of wood trim refinishing on my sailboat . . . http://home.comcast.net/~tpenfield/C22/teak.html
On my powerboats, no wood trim. Your Grady-white is a bit older as I recall, so they still used a bit of teak trim back then.
Badfish95
If your boat has teak, I highly recommend the Starbrite 3 part kit to restore it. There is a cleaner, brightener and then an oil. It takes some elbow grease but you can't beat the end result IMO. Teak is an amazing wood. My old Four Winns had a teak swim deck, stern grab rail and a few wood accent pieces. As long as its not stored on the water all day everyday the finish will look great with just a few applications of oil a month. Also, the oil actually gave the swim platform some tack, so slips were not an issue.
Good luck, and be sure to post before and after photos.
Yacht Dr.
80 grit it and teak oil it if you want a temp thing ..
You can finish it with a few 6 coats of varnish .. you have to keep up with anything you put on there...
YD.
Gradywhite3535
Dammit the site won't let me send pics, i would like to show you the wood i have. I'm not sure if its teak or wood.
Gradywhite3535
Ok so here is the pics! Is this teak? It's sort of a grayish color.
Gradywhite3535
Here are a few things i may be able to use! Will these work?
25thmustang
I wouldn't use any of the products shown.
Do you want a smooth glossy finish? A smooth satin finish? A warm oiled look? A grey natural look?
Deciding how much work your willing to do and what look you want to have in the end is step one. I have 8-10 coats of varnish on 3 coats of epoxy dealer on my teak.
How I got it:
Sanded:
Lots of work later:
Bayou Dave
I sanded my Teak all the way down to bare wood. Used 80 grit and then 100 grit to make it smooth. Then I used Watco Teak Oil and put 4 coats on it by saturating the wood, waiting an hour and a half between coats to make sure it soaked in good. I put a coat on once a week for a month and now put a coat on monthly.
http://forums.iboats.com/attachment.php?attachmentid=178282&d=1357485783
http://forums.iboats.com/attachment.php?attachmentid=178281&d=1357485777
http://forums.iboats.com/attachment.php?attachmentid=178280&d=1357485766
Gradywhite3535
Is the wood i have teak? I just want it to look good and last at least 2 years
Woodonglass
Hard to tell for sure, but base on your pics, I'd guess YES!!!;)
Yacht Dr.
Yes mate .. you have teak.
I would do what DRS suggested personally.
You wont get 2 years out of teak oil.. but its not hard to apply a coat of oil once every other week.
YD.
