What are the best ST225/75R/15 boat tires?
5hondaoutboards
Looking to replace both tires on a single axle trailer. Currently using Carlisle tires and have had no problems with them. Any recommendations?
Thanks
Stinnett21
Had a flat early last year. The wait for the Goodyear was months. Bought a Hankook Vantra instead. So far so good.
briangcc
Local tire shop had PowerKing Trailer King RST available in a E load rating. Got 3 - 2 main and 1 spare. Had em for the season and so far no issues. I replace the tires every 3-5 years, even if they don't look like they need it.
jimmbo
After 12 yrs, one of the Goodyear Marathons came a little unglued
airshot
At 12 years it was well beyond its life expectancy!!! Just had a flat repaired last week....the tire shops will not touch any tire over 7 years old, other than to replace it!! Supposed to be a new regulation...some shops now consider 1/8" tread as worn out, so no repair on those either.
jimmbo
Yet the Wear Bars are far less than 1/8". Sounds more like what Businesses do best, Gouge the Customer
airshot
Yep, the tire mfgrs get together and decide what is best for them, then get it apporoved by the transportation safety board. I can remember when new tires had 3/8" of tread depth or more in some cases, byt not anymore if your lucky you might find 11/32, but many are only 5/16".... subtract the new 1/8" safety standard and your new tires wont last long anymore !!!
BRICH1260
The Goodyear Endurance seem to be the best rated but I have found that the new Carlisle tires are rated highly also.
jimmbo
A few years ago, Carlisle was a Tire that you couldn't even put on a Wheel without having it fail
