I have found the 350 I want to put in the boat. I can buy a new GM engine from scoggin-dickey for 2069.00.
It is 4 bolt, vortec heads, 9.3 compression, roller cam, etc
I am thinking that with a simple cam and spring swap it should be about 350 HP.
The only issue is it says "Not intended for marine use".
What modifications should I make for reliable marine use?
Thanks, Roy
Thanks, Roy
