It's factory. The un burned oil leaks out at the weep holes.
It's normal to see unburnt fuel/oil weeping from various holes in the LU...but looking at your photo, it does not seem like thoses holes are factory??? I have never seen two so close to eachother. But, I do not know your motor either!
Mas
Thats what i thought too but this oil thats seeping out is black...is that normal?
+1. Running some Seafoam through it per the previous post may help. You can get it for about $10 a can at virtually any auto parts store. When used properly, it will remove excess carbon build up within the engine, which should in turn reduce the amount of soot/goo. You should also notice a better idle, increased compression and smoother overall performance after a good decarb. Seafoam also works great in your car, truck and lawnmower, etc.... Do a search here in the forums for how-to threads and/or on youtube. Be warned! It WILL smoke like a mother@#$@#$, but that's just all the old, built up carbon burning away, but you may want to warn the neighbors......seriously.
Man. All that and still leaking black sludge? It may be running way to rich. Just a guess
lol i already ran seafoam in from a brand new gas tank til the gas ran out...i took out the spark plugs and sprayed DEEP CREEP in all 4, and i also poured seafoam into the carburators while it was running until it choked out...is there somewhere else i should put this stuff lol...or do you think it would be better to remove the lower unit and clean it out myself?
It looks to me as there might have been a stuck lower unit bolt, or even one broke off at some point and the holes were drilled to allow penetrating oil to get in the thread channel of the bolt, looks like an effort above the washer as well.
