What automotive versions of parts are safe/reasonable? aq131c
CaptainPtbo
I know the aq131 is a volvo 2.3 liter out of 85-93 240 volvo 8v non turbo "redblock".
I need the following parts, am I ok using the automotive version?
Oil filter
cap, rotor, points, condenser, coil, plugs, wires
frost plugs (i know they're not "frost plugs ;)
thermostat
belt (not the timing one, the one that runs the alt/waterpump etc.)
exhaust manifold gaskets
bonus question - does it have an oil drain plug on the oil pan or do i need to pump it out?
Thanks folks!
J
GA_Boater
Welcome aboard Capt.
What you need to be concerned about is being safe and not causing damage to the motor. It seems you're aware of that already.
Oil filter - Yep
cap, rotor, points, condenser, coil, plugs, wires - All but the cap if Volvo uses a marine cap - I never owned a V-P..
No steel "casting plugs"
thermostat - Should be marine, especially in salt or brackish water and raw water cooling. I never worked on a V-P.
belt (not the timing one, the one that runs the alt/waterpump etc.) - Yep - a belt is a belt.
exhaust manifold gaskets Only between the block and manifold - No water contact so auto is OK.
bonus question - does it have an oil drain plug on the oil pan or do i need to pump it out? - I'm sure you do, so you can drain or pump - But I never had a V-P.
Hope that helps some until the the guys that really know pop in. :smile: Most your questions are generic in nature, in that any marinized motor uses the same general guidelines. Hope to see you on the water. :D
CaptainPtbo
Thanks for the input, and the welcome. I have been reading the forums quite a bit, there's a wealth of information here!
This particular Volvo uses a heat exchanger, so no raw water enters the block or thermostat housing. It would be bathed in coolant only.
So the casting plugs would be ok as well?
Cheers,
J
jerryjerry05
Yes the steel plugs would be ok.
But why are they out? They don't need to be changed????
It does have a drain plug.
But it's a real mess trying to drain in the bilge
I'm not sure but the cap and rotor and points may be marine specific.
Most time a good piece of sandpaper is all you need.
The wires can be generic just make sure they are the right size 6 or 7 maybe 8mm???.
Maybe resistor wires?
The OEM wires ain't cheap. Almost $200
Your thermo is a 180d Just make sure it's the same. Volvo $38
CaptainPtbo
Thanks Jerry Jerry.
One of the casting plugs from the cooling side exhaust manifold I found in the bilge. I pulled the manifold to inspect it, and another one appears to be leaking. I did a little research and it seems to be a bit of a known issue. Possibly just fell out, possibly not properly winterized. I inspected what I could, and didn't see any other evidence of freezing damage.
The oil pan is pretty accessible right now, with the exhaust manifold off, so I think ill try draining it from the bottom.
As far as the ignition stuff there's no known issue, I'm just trying to give it a "good once over" before I plunk her in the water.
Cheers,
J
jerryjerry05
The block wasn't supposed to have water but anti=freeze????
Since the manifolds off, do a flow test.
The manifold should flow as much water out as a hose can produce.
Any signs of back pressure shows a clog.
Any idea how old the manifold is?
I worked on a similar boat.
It was overheating. The owner was convinced the mani was good as it still had shiny paint.
I disconnected the parts and while I was removing it poked a hole in the side(rot)with my finger.
