89-90hp johnson...been having lots of problems with no spark on 1 bank,then it went too good spark on all 4, then it went too weak spark on all 4,I put on a new powerpack and it made no diffrence.. an now the power pack is dead...The stator has 180 volts,ohms are 530 while connected too power pack...the timer base has 43 ohms an 1.7 volts but I had too disconnect the power pack too test, the powerpack is shorted out. the coils had 159-172 volts on all 4 before the power pack went out..I test the kill wire for a short and power an it is good, no voltage at all on wire.I pulled the flywheel and everything there looks good.I have a new powerpack but really neverous about hooking it up.All the wires look good nothing seems too be rubbing anywhere, not sure where too look next. I tested stator and timerbase wires too ground and nothing is shorted out
