What can cause compression loss?
Erude73
aside from bad rings or scored up cylinders, or headgasket,is there anything else that can cause low compression on a 2 stroke? i have a 4 and 15hp for a friend and both on my compression gauge read around 20-30 lbs.
Silvertip
1) bad compression gauge, 2) incorrect compression test procedure, 3) compression gauge not sealing in the plug hole. All three have nothing to do with the condition of the engine. I highly doubt all cylinders are bad -- and bad in the same range. You mentioned "bad rings" but "stuck rings" due to carbon deposits can cause low compression. Otherwise you hit the most common issues.
oldboat1
If the numbers are right, neither one of the motors is running (presumably). Might try a different screw in gauge -- test with both plugs out; pull it over repeatedly until the needle stops rising (maybe four or five pulls).
jimmbo
Warped head and damaged piston crown are two more causes. Poorly done sparkplug thread repair is another
