Re: What can short out a Stator?
Hi John. I had the boat about 4 years and had the same stator on it and one day it just quit. I replaced with the second stator and it only worked for about 5 minutes.
Prior to the first stator blowing, engine had to crank longer than normal. Did stall a couple times but did restart. Boat slow to come up to speed but eventually did come up to speed. This all happened in the same day. Then when it finally died, it never restarted. I replaced stator, fired up immediately and ran great for 5 minutes. I did not check the rectifiers when I replaced the stator.
My rectifiers don't check out properly. Would this be the cause of the stator problem? Did the rectifiers perhaps short the stator out? Or could it be something else? Top crank bearing is tight, fly wheel is tight, not sure if it was a 16 amp stator (checking with place I bought it from) but the stator visually looks like the same as the one that it replaced. Could I just have gotten a bad stator?
Thanks again for your help.
Mike
The 16 amp and 40 amp stators are considerably different in appearance. The laminations are about an eighth inch thicker on the 40, and all 12 poles are exposed, instead of a few of them being encased as is the 16.
A shorted rectifier shouldn't hurt the stator, at least quickly. It could be a factor that along with say, massive engine overheat, could contribute to failure.
If it's the right one, and if the flywheel isn't hitting it, you got a bad new one.
You say rectifiers. (plural) There should be one rectifier module hooked up to a 16 amp stator. Maybe a regulator module hooked up to the rectifier module.
If in doubt, pictures would help.
hope it helps
John
