what color should my trim fluid be
zsmith29
2000 Stingray w merc 4 cyl
I just dipped my finger in the trim fluid reservoir and the fluid look like a vanilla milkshake whitish.....
Is this ok?
EMC 1810SS
Re: what color should my trim fluid be
Mine was always clearish yellow. Milkshake tells me water is getting in the fluid.
thumpar
The color can be different depending on what fluid is used but milkshake is not good.
zsmith29
Ok. What color is that stuff right out of the bottle?
thumpar
Depends on what you are using. Some use hydraulic fluid or trim fluid or motor oil or steering fluid.
airshot
My mercruiser trim unit calls for 20w-50 motor oil. So obviously it is motor oil color.
or ATF
however it should be honey colored if hydraulic fluid, power steering fluid, or motor oil, red if ATF.
if you have a milkshake, your seals on the rams probably need attention.
zsmith29
or ATF
an
Thanks Guys,
But what is "seals on the rams"?
Is this an urgent issue?
thumpar
If it is milkshake I would worry about it. You could take the fluid out and put it in a jar. After a while it will settle and you would know for sure if it is water. If it is water it could be anything on the transom back in the system.
