diggerdan17
- Apr 11, 2003
- 148
i bought a carb kit for my 15 horse evinrude 81.<br />took the carb off and changed the parts that i got with my carb kit.only problem is i have leftovers in the bag that my carb kit came with.i changed the float and the pin that holds the float.ichanged the needle vave and the little wire clip that holds the needle vave.i changed the screw that the needle valve sits in .i changed the float bowl gasket.and i unscrewed the lean rich screw and changed the little red washer ,gasket thingy.i changed the gasket that goes between the carb and the engine.leftover parts are 3 large gaskets about the same size as the float bowl gaskets but have holes and shapes cutout throughout them.i also have a 1 inch long piece of flexible rubber hosing and 4 small washer type gaskets and finally i have an metal piece that looks like the snap of a light vest?did i tottally screw up and miss putting all these parts in?for the life of me i could not see any way to take the carb apart anymore than i did.
