what consist of changing manifold choke to electric?
BowT
I'm replacing my carb on my merc 228. do I have to do anything to change to electric choke ? and what are the wires that run to a switch on my throttle control? I'm replacing my shifter and wandering if I need to replace those wires and switch on the control
Don S
Re: what consist of changing manifold choke to electric?
Get a carb with an electric choke. Wire it in.
dubs283
probably for the trim switch
buy a controller with a trim switch built into it. it will be wired for a switch so all you have to do is route and connect the wires
BowT
it's not a trim switch, it's two yellow wires on some kind of kill switch or something. I may try to get a pic up later of what I'm talking about.
dubs283
neutral saftey switch
the controller has to be in neutral for the engine to turn over
BowT
thank you! so I guess that has to be hooked up again. thanks again
