Re: What did I do? Totally dead. Messing with tilt relay.
Your boat has a 12 volt electrical system. A live circuit anywhere should measure 12 volts minus any small voltage drop due to the length of the wire run and any corrosion. Here are some measurement points.
1) Across the battery = 12.6 volts fully charged.
2) Starter solenoid where large red battery cable connects = 12.6 volts
3) Fuse for the engine harness going to the console = 12.6 volts INTO the fuse.
4) 12.6 volts at the "B" terminal on the ignition switch. If not present, and I suspect it isn't, the issue is at the engine and very likely the fuse. Make sure you check you check ALL of them if there is more than one. And make sure the ONE (if that's all there are} is good. Replace it. Even with the relay out, the engine should start.
Gotcha. Ok, so the relay isn't causing this problem at the moment. Gotcha. Hmm. Battery is a little low. Need to get my charger back from neighbor haha. Didn't check starter solenoid so I'll do that this afternoon. I did check the large fuse at the engine and it was fine, did not verify voltage there though. The ignition switch is a Cole hersee(sticks way out from the dash panel ugh)
http://www.jamestowndistributors.co...ilyName=Cole+Hersee+Ignition+Starter+Switches . I'll look again at the switch but I don't think I was getting power from any of the three terminals.
Just to add to the confusion, there are a number of inline fuses behind instrument panel. When I opened one of them to check, not sure which sadly, it did make the hour meter start ticking for a few seconds. The fuse itself looked ok. I should have noted which gauge it went to. Bah!
Thank you for the diagram Fucawi. I had seen that one but I sort of passed it off looking for another because the color of my wires are a bit different. I didn't know if that meant I had a different circuit or not. After cross referencing relays and circuit for about 3 hours last night, I have come to the conclusion that regardless of color, year, make, model, whether its on land, in the air or on water, they are all the same haha. I'll also be sure to post all of my cross referenced part numbers here for the next bloke whos tilt/trim takes a dive(hopefully Not literally!!)
Thanks for the input guys. Going to order some relays. I was hoping to find them locally for a decent price. Pretty sure that was the initial problem as I removed the tilt motor and verified it spins connected directly to 12v. The relays were heavily corroded from the relay housing being flooded. P/O apparently forgot to screw the top back on it and looks like it filled with rain water. Both relays were oozing rust.
