what did these carbs come off of? V150 0r v200?
prolinews
They have 5 bleed lines and enrichiner system .The #s are WH1-1 my manual codes the jets right but not what they came off of. The bleeder lines match the v150-v200 was there any difference in carbs on these motors? the intake has the 5 petal reeds vertical .
Laddies
Banned
Re: what did these carbs come off of? V150 0r v200?
The WH-1 is common to 150,175.200 V/6 engines but does need differant jets--Bob
prolinews
I'm sorry I put down the wrong #s the correct ones are wh-12-1 I found a v225 stamped on bottom cylinder on the starboard side . The bleeder hose diagram in the manual doesn't match the v225 it matches the v150 - v200 .I found another set of numbers at the powerhead base that I'm going to run through mercpartsexpress 358-7788 .
Laddies
Banned
Good Luck with the project
prolinews
The #s turned up nothing I'm wanting to order a stator and trigger but trying to figure out what year and which one is driving me nuts neither had part#s on them will all carb v/6 parts work? I'm going to replace rectifier at same time. The only # that came up was the crank seal 26-29476 it gave me a price but no indication what it came from.
