what did these parts come off of??????
corbin5754
I am wanting to know what these parts came off of and the correct name for ea part. the smaller one is a impeller housing i think on the front it says jp 3/8".
On bigger part it has a number stamped on it 1-824515. thanks for your help....
superbenk
Re: what did these parts come off of??????
That looks like OMC blue, but I don't recognize the part. Something to do with trim hydraulics? Hard to see.
captmello
The big part is a Volvo penta oil cooler from the early 70s, aq130 perhaps. I suspect the pump is from the same motor.
PiratePast40
^^^^ Yes, I agree. The oil cooler is also used on the later OHC 4 cyl engines with 2 carbs as well as the inline 6. The raw water pump is a Jabsco but don't remember the model number. Some of them have 2 bearings instead of brass bushings, so if you're looking at rebuilding the pump, you should take it apart first to see which kit you need.
