What do you think of my idea?
airdvr1227
I keep reading about people having trouble determining what pitch of prop they should be using. I know from personal experience it gets expensive hanging props and trying them out. What about a disposable hard plastic temporary prop that would be cheap enough to try out?...or as a temporary spare? How much do you think you'd spend on a prop that could be thrown away if it wasn't correct?
Philster
Re: What do you think of my idea?
Plastic doesn't perform like alum or stainless, or even a good composite, so the results would be very, very off. Pitch matters, but the material is very important, too. To compare which SS prop to use, you need a selection of SS props.
wgl333
It would make more sense for a prop shop to have a cross section of props and "rent" them out for trials. Yes, that increases their overhead, but, at $10 or $15 a day for tests (credit card only, of course), they could recoup their investments in short order and probably bring in some new customers as well.
Rocky_Road
There are composite props out there that allow you to exchange your pitch until your are happy.
http://www.piranha.com/
I personally wouldn't use one for my main prop, but I can see how it would make a good backup.
Happy boating!
P.S. I remember a prop that you could actually dial in the pitch you wanted, but my quick search didn't find it. Maybe someone can link this...?
jkust
Yep plastic spare props to use in a pinch have been around for a while. The issue isn't just pitch since every different prop of the same pitch or material may respond differently and every hull will respond differently also. There's lots of permutations There't a lot more to consider than just pitch within a certain range. Many of the questions I have seen lately aren't necessarily only pitch related but related to switching to more blades. As for a spare, I keep a full sized spare in the box on the boat with tools to change it. A standard prop for my Alpha 1 in the box is huge and hogs one entire section of valuable storage. If there were a prop that folded in on itself and took up very little storage space expecially on our sub 20 foot boats. I'd listen but I think the Pirana already saves storage space.
CaryW
Happy boating!
They were talking about it on S&F a week or two ago. Seems that they worked well for the bass boat guys but would come apart if run too close to the surface.
Rocky_Road
Cool!
That seemed to be my gut feeling when I saw them...looks great on paper, but...!
But I still wouldn't mind a composite single pitched prop as my spare. It could sit in the bottom of my boat without much worry about it being in a damp environment, and the light weight would be a plus.
Happy boating!
solar7647
I use an adjusable pro pulse prop that is composition. I love it! I have a spare set of blades on the boat incase I break one on the water but have not used them yet. I have had it for two years now with no issue. Originally had it on 180hp but now have it on a 205hp. It has great grab and little slip compared to an aluminum. I am convinced and won't be changing to metal any time soon. It great wake boarding, tubing and fishing out on lake Erie. Just my 2 cents
