What does too much oil do to the motor?
texantommyray
I have a 88 Yamaha 90 and i never trust oil injection so I mix it in the tank (50:1), but I never disconnected the oil injection. So its getting double the oil i presume. Im sure its not good for the motor. Can someone tell me What harm this is doing to my motor.
Thanks
Tommy
Mas
Re: What does too much oil do to the motor?
You will foul plugs quickly and create carbon build-up in the cylinders. Both will lower efficiency.
MAS
deejaycee_2000
It will not do any harm, it will only smoke alot, why don't you disconnect the oil injection? it is quick and easy ..... carbon buildup is not a bad thing as it adds compression and therefor will increase performance .....
