kfogart3
- Aug 10, 2020
- 5
Hello everyone,
Long story short, my local mechanic pointed out a leak in the powerhead gasket on my 87' 88hp evinrude which is contributing to a rough idle. They quoted me ~8+ hr of labor, so I am doing it myself. The engine looks pretty clean, considering its older than I am, and compression is all 115-120, so I am hoping I can keep it going for a while.
After wrestling around with the studs for a couple days, I have the powerhead completely removed. Needless to say, I don't want to do it again, so what else should I look at and replace while I am in here? I already did the water pump and got new thermostats. Should I dig into the exhaust housing more to replace any other gaskets?
I have been taking a lot of pictures just in case I want to do a write-up when i am done, but here are a couple that show the adapter plate condition. I also included a picture of the hose fittings that go to the thermostat housing. It looked like there was some buildup, is this normal? I was going to just clean it up as best as possible.
Thanks,
Kevin
Thanks,
Kevin
