What fluids should I have?
paulspaddle
My first i/o. 1990 4.3, Alpha 1.
I'm reading through the manuals and to be honest it's seems overwhelming at times, "when doing such and such, lube with ----- brand, and make sure such and such level is filled with ----"
Could someone shortcut this and help me put together a complete lube and fluid 'tickle trunk'?
I have to admit I don't change my own fluids in my vehicles so I don't have a shelf full of products. At this time I'm self employed and can justify paying someone to do that...but I cannot justify paying for someone to maintain a 'toy'.
Thanks!
180shabah
Re: What fluids should I have?
I think you need to read through the entire section of the manual (it is a factory manual, right?) covering winter layup and spring commissioning before you decide that you will DIY. It is alot more involved than just a quick lube, oil, filter change.
some fluids/lubricants needed:
oil - 25W40
PS fluid
Trim fluid
spline/coupler grease
gimble bearing grease
Wheel bearing grease (for trailer)
perfect seal
fogging oil
fuel stabilizer
etc.
paulspaddle
Thanks for the list, I hear your words of caution.
I ask lots of questions, but am confident I can DIY. The learning curve is steep at the moment and in a few months I may be rolling my eyes at my own questions I'm asking now.
Learning about this motor and drive is a great winter distraction!
Don S
Go up to the top of this forum, and click on the sticky titled ADULTS ONLY.
Things there you need to read.
paulspaddle
Thanks Don, I've downloaded and printed the manuals for the outdrive and motor.
Ayuh,... That's Good,.. But, Have you totally explored All the listings in the Adults Only section,..??
Both the Winterization thread,+ the Summerization threads, when combined pretty much cover All the regular maintanance Required for hour upon hour of care free boatin'..
