What gear oil can be used
bigal2522
I am changing the gear oil on my Volvo penta 5.0. It requires GL5 70w 90 synthetic gear oil. Can I use a regular gear oil GL5 70W 90 rather than synthetic???
Augoose
Re: What gear oil can be used
...It requires GL5 70w 90 synthetic gear oil...
I think you have already answered your own question! :)
I WOULD NOT use conventional oil on a drive which calls for synthetic.
Are you willing to risk a $3,000 drive over a couple of bucks difference per bottle?
I'd do what the factory manual calls for and have piece of mind.
wrench 3
You didn't give much information on your drive, but you're probably running cone clutches instead of dog clutches. They create more heat when shifting.
jeffnick
I can sympathies with the questioning by the OP. I have always questioned whether the written instructions were the only way to go. I'm 70 years old now and have hundreds of 'Operating Manual requirement' challenges behind me.
My advice: If you ever question the manual/specifications, go with the manual. If/when you no longer question what the manual says - do what you want.
tazrig
+1^^^ Big time!!!
Bt Doctur
post the mode type and I can post a blowup
Bt Doctur
skydiveD30571
Also, as mentioned in other threads, avoid LS (limited slip) gear oils on the Volvo and bravo drives with cone clutches.
bruceb58
I used to use the Mobil 1 in my drives but have now just gone to using the Volvo oil since all the Mobil 1 bottles I see mention LS.
K-2
Amsoil 75W/80W-90 Universal Synthetic Marine Gear Oil works good.
Less $ than VP oil.
I do not sell Amsoil.
