what happens if you put the venturi in backwards?
emckelvy
Re: what happens if you put the venturi in backwards?
It might cause the motor to run a bit strangely but I wouldn't expect a drastic effect. What are the symptoms?
indy440
When I tried to put it in the way the diagram shows it would not go, so there is only one way for them to fit. The boat is just a turd...
James R
Wont make much difference.
