What happens next....................
Dunaruna
[colour=blue]A semi with a low-loader, on the low-loader is an 8 ton backhoe. The shovel arm of the backhoe is extended almost vertically.
The semi is hurtling down the highway at 60mph. It is a clear and calm day and the highway is flat and straight.
Up ahead is a multi-lane vehicular overpass made of concrete with steel reinforcement.
What happens next?
A: The driver sees the overpass and realises that the backhoe won't fit, he brakes and stops safely.
B: The backhoe hits the overpass which causes it to tip off the low-loader and crash onto the highway.
C: The backhoe hits the overpass and snaps off the shovel arm.
D: The backhoe slices the overpass in half.
(You just know that pics are gunna follow!!)
Re: What happens next....................
C..............
Been There,......... Done That.................
Actually,..... I wasn't the Driver,....... I'm the Mechanic that cleaned up the Mess.............
It was at the base of the 1000 Islands Bridge,.....17 years ago........
SS MAYFLOAT
Hey, I saw where that happened in Orlando when on vacation. It took out a 4 foot slice of the overpass, busted the hold down chains on the hoe, and tore up the hydraulic hoses on the hoe. Had traffice backed up for half the day. That type of accident can tear things up in a hurry.
So what happened in your case?
Dunaruna
[colour=blue]Not yet. But I'll give you a clue - Bondo didn't clean this up.
RubberFrog
I want to see the pictures!
Fishin' Jeff
I guess B and C...maybe D too:^
Dunaruna
[colour=blue]O/k o/k, don't get your panties in a twist!
tommays
that looks SO close to falling down :%
i guess they should have used more rebar :)
Tommays
LadyFish
Thats is NOT what I would have expected.:^
rottenray6402
Ensign
That seems almost impossible that it could slice that far through reinforced concrete! That truck must have been hauling! I would think the sudden stop didn't do the driver any good. :^
oddjob
I'm more concerned/ miffed about the truck driver AND the equipment operator.
It used to be standard industry practice ....to lower the boom of all heavy equipment when not in operation. I wont even address the way it was loaded and carried down the highway in this situation.
I dont miss heavy contruction and I especailly steer clear of todays equipment operators on and off the road.
JRJ
That's one tuff machine and a weak bridge:% A go-ahead driver though8)
kenimpzoom
Sunday I was follwing an 18 wheeler on the highway. Flashing lights turned on indicating to the 18 wheeler to take an alternate route as his trailer was too tall to fit under the bridge.
He ignored and went right under. I backed way off as I thought he was going to slam into the 13 ft tall opening.
He barely fit. I guess he either knew he would fit or didnt see the flashing lights.
Ken
SS MAYFLOAT
Dang on, that did more damage than the one I saw in Orlando. Did that happen at night by any chance?
I know around here, contractors will move their heavy machinery. Less traffic and sometimes they will get by without permits. Those are the ones that seem to always be in a big hurry.
12Footer
The only good trackhoe is a dead trackhoe.
JRJ
What ya got against hoes 12FOOTER? Looks like an excavator anyway:)
QC
Holy flyin' flippin' wow . . . I would have never guessed it could do that. Man!!
Speedwagon
That'd certainly be an eye-opener/high pucker factor for the person travelling on top of the bridge, to suddenly see THAT in front of you.
And how stupid do you have to be, to drive a truck around that is 20-30ft(?) tall, and head straight for an overpass! I'd take that morons CDL away immediately!
rottenray6402
Ensign
Probably will have to replace the seat in the truck, sure would if I'd been driving! :^:^
