What hummingbird unit can i order to work with this transponder?
ThrottleBack
New to me boat has a transponder and wiring already on it. Mount in the boat is for a Hummingbird. If I can find a cheap/used unit to just plug in to the existing setup that would be great.
Alumarine
Re: What hummingbird unit can i order to work with this transponder?
I'm guessing most will work but some of the higher end one's might not be able to do Down or Side Imaging with that one.
ThrottleBack
I just need something simple/cheap. I don't need it to find the fish really, i'm on small lakes anyway for the most part. I just want to know the depth and type of bottom I'm over
NYBo
That's the same connector used on my 385ci and my PiranhaMAX 210. Of course, they both came with a transducer...
Alumarine
You can probably pick one up for 50-100 then and like nybo says - they come with a transducer.
GA_Boater
That's an XNT 9 20 T (temp) or XNT 9 20 (no temp) Check here for compatible heads, then check ebay - all lot of heads there with no transducers.
ThrottleBack
Sweet thanks guys. I have one of those super cheap ebay ones where you just put the float in the water but if i can get one of these i'm sure it's got to be better
