Re: What if anything would I notice from 3 to 4 blade prop
Yes, at least that is the idea.
On a "fixed" drive (straight axle, sail boat drive, etc), a RH rotating propeller will try to pull the stern to the right, turning the vessel to the left. On a stern drive, same principle, but since it'll "pull" (or rather try to to turn) the drive, the vessel will tend to turn to the right. This is due to water having higher density/pressure at the lower (deeper water) half of a propeller than at the upper.
So on a RH rotating propeller, the the prop will try to "move/turn/pull" the sterndrive to the right, thereby the boat will turn to the right. To prevent this, you adjust trim the little trim fin above the propeller in the same direction. The fin will then force the drive in the opposite direction, compensating for the force of the propeller.
So, in this case, you have to put force on the wheel to prevent boat from turning more and more to the right. Turning the trim fin to the right will help you reduce the torque steer.
That is at least in theory - and the way it worked on my 3-blade propeller. On my new 4-blade Solas, I actually had to adjust the trim fin a bit in the OTHER direction (illogical, but latest experience from being out this weekend)...
And, as you might have seen in my updated post, I went too far down in pitch when going from 3-blade to 4-blade (dropped 2" in pitch) and is now horribly under propped. Can easily reach 6,000 and only 26 knots, about 500-1,000 rpm too high, and about 10 knots too slow.
