jcornell26
- Apr 9, 2012
- 92
Alright, Here is the back story. Bought a 2001 Galaxie 1800 Deckboat with Volvo Penta 4.3 GL 190 hp I/O back in April. The seller said it was a new battery (so he says) but it did look pretty new. A month ago I had to get a new battery because it was shot an not accepting a charge. I bought an Everlast Deep Cycle Marine battery from AutoZone. Not long after I had my mechanic out working on something and asked him to make sure my alternator was working properly because of the battery issue. he tested it and said it was operating perfectly at 14V's while the engine was started. He recommended I disconnect the positive from the engine when not in use, and I have been doing so when not in use.
So, the first couple weekends out everything was fine. Boat cranked right up after sitting for a week and sitting for a few hours while we were "beached" at the sandbar. Two weekends ago it was crappy all weekend and we didn't take the boat out. I wanted to make sure the battery was still OK, so i fired her up on Sunday. Cranked right up and let it run for 5 mins, then shut her down.
Fast forward to the next weekend (last Sat). Connect the battery leads up and go to crank her...shes dead. I jump it with my truck, and we head out on the lake. Cruised around for 45mins-an hour and then stopped at the sandbar. After being there 20mins I try and turn her over just to see, and it's dead.
Luckily someone had a jump box and let me use it so I got it started. I called my Mechanic that night and he thought that the alternator didn't have time to fully charge the battery while we were cruising. I went out and bought a charger and left it on overnight. When I hooked up the battery it was at 95%. So, from not being able to start it at the sandbar to a 10 min ride back to the dock it was sitting at 95% charge.
Next day, battery is fully charged, and we head out again. Engine turns over right away. Cruise for about a half hour and then stop at the sandbar. 15 mins after the engine was shut down I want to see if she fires up.........nope. Dead. I got my hands on mt neighbors jump box and got it started...but what gives?
Couple things. I am exchanging my battery tonight form AutoZone as there is a 1 yr warranty on the Everlast's. Hopefully its just a bad battery. Something is drawing power though, and fast? Do you think I needed to also disconnect my stereo and bilge when not in use. To combat this I am going to install a Battery Kill switch. Can someone refer me to a simple inexpensive one that will work for just engine/radio kill? I should keep the bilge hard wired right?
Sorry for the long post, but I thought you should have the background on the last month of activity.
