What is it?
mattsmall1972
Just a random question... on my 1978 OMC 2.5L there's a bell-shaped thing with a clear glass window that says "if you see gas in here..." then do something, I can;'t remember what. It's hooked to the bottom of the gas pump. What is this thing?
Thanks,
Matt
tie_one_on
Re: What is it?
It's a fuel bowl that would catch any gas leaking from a bad fuel pump diaphram. You don't want to see gas in there. If you do "replace the fuel pump".
Kevin70
Re: What is it?
That's one of those things you should check before every outing. If that bowl gets full without your noticing it, it could get dangerous.
