Hello first Time posting but have been reading to fix certain issue.
I purchased a 85 astroglass bass boat with a 85 merc 115 inline 6. I purchased it not running. I have replaced the stator, trigger, rectifier and both switch boxes.
have the boat finally running good had to adjust timing and replace the end cap gasket as well.
To my question. The dash has a red light on it the lights up once in awhile. I first thought it was a over heat warning. And I basically thought I needed to replace impeller. But today I noticed on the motor near the transom a microswitch that has a metal leveler with a wheel on it. That when i push the leveler in the light on the dash lights up. Is this some type of trim warning light?
or a hole shot light? Cannot be tilt as the switch needs the motor trimmed down to activate the light? So my question is what is this? What is in t for? Sorry this is not my first or second boat. Rebuilt a lower unit on a 60 evinrude last year. Just no idea what this is for so I'm interested.
Thank you
Thank you
