What is Normal operating temperature for 2006 Nissan 30 Hp 4 stroke EFI?
captain erika
I looked at owners Manuel called parts department! It’s like pulling hens teeth! I have a shout out to Tohatsu but thought I would ask here. Thanks
pvanv
Assuming your actual model (you didn't say, and year is irrelevant) is MFS30B. The thermostat has a start-to-open temperature of 60C. That's about 140F. If you use an IR thermometer, you will see different temperatures at different locations. Expect the highest to be somewhere around 150F. If you see readings up at 180 or higher, you are overheating.
