1977 merc 1150 IL6 115hp 20"shaft. manual has been orderd, so dont say it ...... :)
P phatmanmike Captain Joined Oct 24, 2003 Messages 3,869 Apr 3, 2004 #1 1977 merc 1150 IL6 115hp 20"shaft. manual has been orderd, so dont say it ......
2 2cycle Petty Officer 1st Class Joined Mar 12, 2004 Messages 234 Apr 3, 2004 #2 Re: what is oil capcity for lower unit If I rememember correctly in filling my 74 1500, I think it was right at one quart when lube started coming out the top vent screw. Hopefully others can chime in and give a more precise answer. Hope this gives a general idea.
M Mercury140-I6 Petty Officer 1st Class Joined Nov 6, 2003 Messages 339 Apr 3, 2004 #3 Re: what is oil capcity for lower unit Sounds about right 2cycle. 2 of the tubes of lube should be just about rightor 1 of the bottles with the pumps.<br /><br />I put Amsoil Lower unit lube in mine and gained 150 RPM's to play with. You might want to try that also.<br /><br />Craig<br /><br /> http://www.myfishingpictures.com/showphoto.php?photo=13002&sort=7&thecat=500&password=
