What is roll and tip painting?
I've tried to figure it out by reading peoples' posts, and I think I get it, but can anyone describe the exact technique for "roll and tip" painting, please?
Bob_VT
Re: What is roll and tip painting?
Goint to shift this to the Paint shop ;) ....our restoration section :D
mike64
I remembered a resto thread by stevewolverton that had a good description of his experience with roll & tip painting. Just a couple paragraphs, but some good roll & tip tips in there. Here's the post (couple posts down on 2nd page):
http://forums.iboats.com/showthread.php?t=243848&page=2
And here's the quote if you don't want to wade through the whole thread:
I was really happy with the way the bottom came out. It's a damn shame that it's hidden under the boat.
I used 220 grit sandpaper on the bottom. I used Petit Easypoxy paint (1 part polyurethane) for the hull.
I used the roll & tip method of applying the paint. I followed the instructions on the can and it worked very well. No runs, and no flat spots. I applied two coats. It didn't take much paint at all to cover the hull. I used one quart. I really thought it would take more, but was pleasantly surprised.
I wiped the boat with acetone before applying the paint. I used a small (6" foam) roller to roll the paint in one hand, and used a 3" wide natural bristle brush to lightly drag across the rolled paint to bust tiny air bubbles (tipping off) from the roller. There have been volumes written on painting boats so I won't get into it much. My biggest tip would be to use very little paint on the roller - really work it into the pan to remove the paint so you have a lightly loaded roller. It's best to cover small areas at a time and work quickly. You don't have to paint like a madman, but work quickly enough to keep a wet edge and you'll be fine. It's not nearly as difficult as many make sound. I have the painting skills of a retarded monkey and I still managed to do a nice job.
Thanks, everyone. Sounds like it works well, but I'm sure I'll find a way to goon it up.
