What is the best electric fuel pump to work on my 97 bayliner trophy?
treeeman00
I am installing a electric fuel pump on my 87 bayliner trophy. I replaced the motor with a newer non vortech 350 so I have to use electric fuel pump. My problem is all the pumps push fuel. My fuel outlet is on the top of my tank. I can mount the pump a little bit lower than the top of the tank. If I mount it at the bottom it will have to be in the botom of the bilge so I cant do that. Will it work if its like 5 inches below the top of the tank? I have a cheap 12s mr gasket fuel pump that I put on to see if it would push the fuel and it did to my surprise so im assuming the holly will work. Any help is greatly appreciated!
Maclin
Re: What is the best electric fuel pump to work on my 97 bayliner trophy?
I do not have a preference or recommendation for a brand other then it must be certified for Marine use.
I will ask if you have plans to wire it such that it can only run when the engine is running or while cranking the engine. This is a safety issue for marine installations. If you do not have such plans now I suggest you not install any electric fuel pump until you research some options and obtain the necessary components to install and wire in along with the fuel pump.
Typical installs use an oil pressure safety switch installed on the engine. This switch only closes when it senses enough oil pressure, usually 5psi or so. The main power supply wire of sufficient gauge is run from a 12v ignition power source to one terminal on this switch and then run from the other terminal to the fuel pump. Along with this there must be a bypass that will get power only when the ignition switch is in Start. This can be a long wire of sufficient gauge running all the way from that switch, or can be run from the starter solenoid where the igniton switch Start wire connects. Some opt for a momentary push button or spring loaded lever type switch that the operator must hold in for a few seconds to allow the pump to run and fill the carb bowl before starting, just getting enough fuel in so the engine will start and run for a few seconds (long enough to build oil pressure so the oil pressure switch will close).
treeeman00
Well I bought a walbro frb-13 electric fuel pump that is certified for marine use but I cannot get it to prime or pump or push any fuel so I am looking to get info on what other pumps people are using. All of the electric fuel pumps that I have found requre that the pump be mounted at the lowest point of the fuel tanlk nd if I do that it would be in the bottom of the bilge. I do have it wire up to run off of an oil pressure switch so that the pump only runs when the motor is cranking and running.
Don S
If you have an air leak in the fuel system to the pump, it will not pump. Same with a plugged up pickup or anti-siphon valve.
I really don't understand that comment. The normally don't mount in the tank, and it's normal for elecrtric fuel pumps to be mounted higher than the fuel tank.
treeeman00
i meant that all of the pumps I have found said they should be mounted below the fuel tank as they are designed to push fuel and not suck such as holley's After I couldnt get the walbro to work right I had a little mr gasket fuel pump that
I tried and it worked fine. Im sure the pickup is not plugged because I blew compressed air into the carb line when it was disconnected and i could hear it blowing into the fuel tank.
Don S
I was referring to the fuel system between the fuel tank and the fuel pump (suction side), not from the pump to the carb (pressure side).
treeeman00
if i blew it into the carb side wouldnt it pressurize the whole thing?
