What is the best prop for my boat?
dirtyoldman
I have a new boat that I haven't run much yet. The prop on there is a 14.75x19. The boat is a 1987 Sea ray sorrento 210 open bow with 260hp mercruiser v8 stern drive.
I was hoping to get one set up for water sports and one for cruising. I have a bunch of props that are too small that I was going to take to the local boat shop and try to do some horse trading for one a good size.
usskydvr
Re: What is the best prop for my boat?
You really need to know your current WOT with average load before any attempt to guess at prop sizes.
Ayuh,.... There juat Ain't any short cuts,... Start here....
dirtyoldman
Wow - you guys are ressurecting an old thread here.
No problem, I've been experimenting and ahve more data.
I have a 1987 sea ray sorrento 21', a fairly heavy boat. I think it's around 3500 lbs. It has a 260hp v8 with alpha 1. I don't know of any performance mods.
The boat takes a few seconds to get on plane. It doesn't seem to plane out until about 25 MPH. It also runs very high rpm's. With a 19 pitch aluminum prop I was runnign 5400 RPM at WOT, and with a 21 pitch I was running 5000rpm at 50 mph. It was choppy yesterday, so I plan on trying again tomorrow and expect to do better with more trim. None of my props are in very good shape. I boat mainly on small lakes so speed and even mileage isn't really a big deal, but we do go to some bigger lakes where it is more of a big deal too, so i was wanting to end up with two props - one for lakes around here and skiing, and another for the bigger lakes and mid range cruising.
steelespike
What is the max rated rpm?You must be close at 5,000.
