what is the boat manufacturer ?????
garyq
70hp out board with the marker lights on the side and the splash rails someone should know this boat....
Re: what is the boat manufacturer ?????
Ayuh,.... Looks like an ole Starcraft Holiday to me...
garyq
what company made me?????
1972 to 1978 I THINK with the side marker lights and hull splash rail some one should know this boat out board motor 70 hp ,any guess out there3881759_20.jpg
garyq
would you have any photo and have you ever seen the lights on the side like this
NHGuy
Re: what company made me?????
Looks like a Starcraft.
garyq
have you ever seen lights on the side be for what yr do you think
NoKlu
These are very popular boats and a quick google search will get you all kinds of pictures. There are several that have been restored here. The search feature is your friend.
reelfishin
I would guess that the side navigation lights were used in place of the forward nav lamp to make room for an anchor pulley or winch?
The boat doesn't really look like a Starcraft, the windshield is a two panel unit, with top wipers, the bow breast plate or upper keel looks more angular than a Starcraft and the spray rail doesn't continue the full length of the hull
Where is that boat from? USA or other?
garyq
the boat is from canada and it has the bow marker lights also
garyq
oka thanks
Bob_VT
merged posts
ziggy
if it's a 1973 or newer and built in the usa it'll have a hin on it somewhere. starboard side of the transom is most likely location. the hin will for sure let ya know who the mfg. is..
ezmobee
Although similar, I do not believe that to be a Starcraft.
garyq
could this be a ALuminum Goods Corp.Ltd that went to Mirro Aluminum Comp
then Mirrocraft still being sold as Northport???I need some pictures to match up
model # is 1676 does this mean 16 feet long and built in 1976 ?? found more # on the hin plate WD156 ---238420 ---SOE100181 MAX load 1556lbs
steelespike
I have a 57 and 77 Crestliner with those side lights that I were installed by me.
Likely the same for yours.Disregarding the spray rails it still doesn't look right for a Starcraft.You might look at fiberglassics.com many boat catalogs some with aluminum models.
steelespike
As far as the spray rails the 57 Crestliners had at least 2 comepletely different style spray rails. I'm sure other brands had similar styling cue differences.
garyq
well thanks for trying not much info .I think its a Mirrocraft or a Northport but is it a Holiday or Sport Runabout model and about what yr I mite try go to the library and look up these two boat companies thanks for your help ..
mr 88
I doubt it is a Mirror Craft as they were made in the USA and you posted it was Canadian made. They are also welded and have a full splash guard running the length of the boat.
garyq
HI MR88 not so sure about that? Mirrocraft has had three name changes Mirro Aluminum company for one problem is this boat looks very close to the others but I need to see one like mine to know what kind it is..
