kentuckybassman18
- May 12, 2004
- 23
what is the diffenes in a rectifier and a voltage regulator? does the rectifier have anything to do with a rpm gauge? or does the voltage regulator have something to do with the rpm gauge? if the rectifier is bad will the rpm gauge not work? or if the voltage regulator is bad will it make the rpm gauge not work? so what does make the rpm gauge work?
