What is the little unit next the tilt and trim on my 2001 johnson 50hp?
wilson750
What is the little unit with the spring that you can move up and down with my johnson 50hp? The new used trim unit i got has it, and the one on the motor appears the other owner took it off..The orginal owner left the 3 wires there just taped them up..What does this unit do? And should i put it back on or leave it off?
Joe Reeves
Re: What is the little unit next the tilt and trim on my 2001 johnson 50hp?
That's the sender for the PTT gauge. Check with the previous owner.... possibly it is no good, hence being taped off.
wilson750
It didnt have one on the boat..Seemed to work fine without it..Would you put it back on or leave it off? Whats it do?
boobie
It's a sender unit for the T/T gauge to tell you mtr position when tilting up and down.
Joe Reeves
The gauge really has nothing to do with the operation of the PTT unit, it just shows you the tilt position of the engine at any given time. You don't need it.
wilson750
Thanks guys..Im just gonna leave it off then..
Silvertip
If you can turn your head and see the attitude of the engine you don't need a trim gauge. If you have a large boat and cannot see the engine, then the trim gauge has some value.
