What is the missing part?
robtherep
Hello<br />The FDE-11 1957 18 HP Johnson I am trying to fix has a plate, cover or something missing on a reservoir just on top of the carb. I don’t know if i can just make a metal plate or if it needs a part.<br />Is this a air filter chamber like on a lawnmower that holds a sponge? Should the lid I make have a gasket or vents or is something else necessary.<br /><br />Thanks <br />Rob
Solittle
Re: What is the missing part?
Rob - Your best bet is to get the omc shop & parts manual & go from there. My guess is that you will need to hit ebay or a marine junkpile for another carb.
Paul Moir
Sounds like you're missing the top half of the air silencer. Have a look at Geekomatic's '58:<br /> http://photobucket.com/albums/y18/geekomatic/?action=view&current=P4051196.jpg <br /><br />There's no filter or anything in there. It's just to keep the intake noise down. Your outboard will start & run fine without it in place, but if you want to get a new one, have tcoutboard.com or some such online outboard junkyard send you a replacement. Can't cost much.
robtherep
That’s fantastic thanks guys. It’s the top part of the little blue tank on the right side of the pic. <br />Just below it is a little silver coloured thing with a black rubber top on it? I’m not sure what it is and the top is somehow come loose.
lark2004
the little silver thing.... Thats a choke solenoid.
