frankygandolfo
- Jul 5, 2022
- 20
Inspected the check-valves also, (if equipped with) fittings are the check-valvescopy that, thanks brotha !
check valves are located where on the engine, do you have a pic of the location. sry very very new to outboard engines but am pretty decent with car mechanics.Inspected the check-valves also, (if equipped with) fittings are the check-valves
poor idle sluggishness, cleaned out the small screens and seems to be running steady.First you should tell us what the problem is your having?
Never really run across a problem with the dog bone.
They can get clogged with carbon pieces.
But since the advent of TCW-3 oils the carbon problems is not much of a problem.
thanks buddy, appreciate the help, it seems to be running steady nowNo problem.....if you still have issues after this there are some hard hitters on here that can help you out for sure.![]()
The check valve is built into the fitting the hose pushes onto on the dog bone.....might spray some carb cleaner in there to clean it.....take the boat out and see how it does on the water, under load. Sometimes it runs great in the driveway, and different on the water.check valves are located where on the engine, do you have a pic of the location. sry very very new to outboard engines but am pretty decent with car mechanics.
