What is the right propeller to my boat??
Branco Ventura
Hello, hope everything ok with all.
I'm from Portugal and I have a little problem to find the right propeller to my boat.
My old propeller its very very worn and i need to find the right propeller according my engine, my Drives and boat.
Boat is:
Campion Allante 185
Engine: Volvo Penta 431, 205Hp Gasoline
Number: 4100125618
Drives(columm in Portuguese): Volvo Penta 868130
Number: 1101585371
The Question is, which is the correct propeller i need to search, reference and size.? Can anyone help me??
Best regards to all.
Ayuh,...... Welcome Aboard,...... What are the numbers on the ole prop,..??
Sea Rider
Yep, if you don't post actual wot rpm water test as loaded won't know if current prop revs inside safe rpm parameters, being middle to max wot rpm range preferred. Buy same new prop or go for usually less prop pitch to pull wot revs bit higher if in need to better hole shot. Will need to know factory stated wot rpm range for that engine to play with props..
Happy Boating
QBhoy
Is this a single prop or duo prop ? Most 431/205A were coupled to a 290dp leg. That’s a whole different issue.
As mentioned. Really need more details around current set up
