what is this gauge?
Clutzmi
im new to boating and cannot for the life of me find what this gauge does any help would be appreciated
sschefer
Re: what is this gauge?
Water Pressure for your outboard. If it's hooked up it will tell you if the waterpump is pumping water without having to check the tell tale.
Clutzmi
then i guess its not hooked up the previous owner put a 90 hp evinrude on it, does anyone know if it can still be hooked up and if so how. im a stickler for all my stuff working the boat is an older starcraft and the motor is a 1982 90hp evinrude
glust
You've got to run an airline hose from the back of the gauge to a place on the motor where you can T off of the hose leading to the pee hole. That hose will then carry water and some air back to the gauge. The air will be trapped between the water and the gauge and will indicate the pressure on the gauge. I use mine quite a bit on startup just to make sure I have good water pressure. I have a partyhut 30 and my motor and the pee hole are not easy to see from the helm so the gauge is very helpful. Good luck!
seapro204
Awesome thread and Awesome answers. I have just purchased a 1990 SeaPro 204 and that same gauge is on there. The best part is, I could not figure out why there was a T on my pisser tube and what the heck the air hose in the back of my boat was. LOL this is awesome.
Clutzmi
hooked everything up last weekend and it works great now on the the next problem. thanks for all the help
Bamaman1
Every 2 stroke needs such a gauge. You don't see'em on 4 strokes, however.
cat toon
You are correct one can not see the pee tube for the top on the toon especiall when it in the stow position.
cat toon
I need help plumming my water pressure gague,swaped motors from a 50 horse Merc to a 70 horse jonson thegague hook-up is very different,how can I hook the johnson to the gague?
Grub54891
Same as the above comment's, just "t" it off the pisser,run the line to the guadge good to go.....
steelespike
Don't see the need on a 2 stroke over a 4 stroke.The cooling is basically identical on each.?
In fact I would think the 2 stroke would be slightly less sensitive being that it doesn't have the need to keep the exhaust valves
and confined exhaust passages cool.
Silvertip
And just what makes you think that??? That engine still has a water pump and an water pump not doing it's job can still ruin an engine. Many people feel the WP gauge somehow provides an indication of overheating as well. It most certainly does not. It tells you IF, and HOW WELL the water pump is doing its job. The pump can expell water like a race horse but the engine can still be overheating so the temperature alarm and/or a water TEMP gauge are still needed.
filthy
yup, had that on one of my outboards, heaps o water coming out the pee hole but kept overheating, turns out half the block was plugged up with gunk! really do need a temp guage!
