What is this in lower unit of Mercury 90hp
Cptkid570
Ensign
Part #9 and the balls are a detent assembly.----Likely not visible and best left alone.
Cptkid570
Ensign
I found 2 of the 3 ball bearings though.. so I figured that I had to replace that.. maybe the ball bearings came from something else? I also can't find that spring.. and part #7 was found behind the forward gear. I just want to put it back together right. I found he spring on ebay... can't find this detent assembly thing
Cptkid570
Ensign
Do you know of any videos that illustrate this? I can't find anything.. the shift dog was torn up too and I'm replacing that as well
If the shift dog broke it would explain why you found these pieces loose in there.
