What is This in the Picture
longstand
How do i use this. i cant figure it out..
I could switch it to Bow or AFT. or on the left. when has no name.. i cant figure this out..
can i switch it where it will get gas from both AFT and BOW gas tank?
longstand
Re: What is This in the Picture
What about this one..
How do i use this.. i know i have to connect the extesion cord to the side of the boat to the house... but do i turn off the main battery switch to OFF. or ON..
i ask because. when the main switch is oFF. the readon on this BOX goes up to the 15AMP on the Gauges
also . does it charge my battery??
i was planning of buying a honda generator the and rewire this converter to the generator so it could power all the outlet on the boat so i could watch TV or what ever i want to use and also charge the battery when my engine is OFF...
love1u0
It looks like going to the left shuts it off.. It doesnt look like you can get it out of both tanks at the same time.
longstand
There is two hose coming out.. they both connect to the thermostat housing.
i just want to know which one connects where. i forgot..
iam thinking that 1 hose connects to where the water still cold.
the other connects where the other to the water pump..
just guest. cant figure it out
how does this water heater work.. i know it use electricity to work. but ..>> i just dont get it.. . because i dont see
Alpheus
The battery charger turns on when you have shore power connected and your battery turned off. The meter is showing that your battery is drawing 15 amps. The water heater just uses heat from the engine to help rise the temp in your water heaters. As for the fuel petcock take the hose clamps off and look at the valve.
I think you should be looking around for an owners manual and start reading...
myoldboat2
My boat used to have a water heater. When underway, some of the hot water from the engine was routed through the small hose coming off the t-stat housing and into the water heater. There it would wind its way through coils and then dump overboard. Some of the heat would be transferred into the water tank inside the heater, to heat water from the fresh water tank.
longstand
I been doing alot of reading.. i dont have the owner manual. but i do have the after market repair manual and do not mention little things like this..
it assume i know it.. but i dont..
i even gooogle this question. but no luck. iam just to new on this boating stuff
Sonama
I have the same fuel valve on my boat and you can select one tank or the other but you can't select both at the same time.
Jean
