What is this part? Off my 1964 water pump
baldwisa
When pulling my water pump i noticed this inside my water pump housing. Looks like some kind of spring like O-ring. Not sure where it goes or if i need to replace something. 20150813_214819_resized.jpg
baldwisa
I needed to replace the grommet as well. I'm having a hard time getting it to seat properly. Any tips? The new one i ordered off this site doesn't look like the old one. IMG_1557.JPG
GA_Boater
I'm not familiar with JonnyRudes, but the looks like the spring from a seal. Probably the driveshaft seal in the upper pump housing.
F_R
Remove the cap off the pump housing and you will see the seal that the spring fell out of. Seal is part number 308073. Grommet is part number 310372. Dealer items, I don't believe iboats has them.
baldwisa
Thanks guys. Any tips for getting the lower unit back on? The new grommet on the water pump is hard to fit over the water line
boobie
Put some marine grease on it, Also grease the drive shaft splines on the sides.
F_R
I thought you said it was the wrong grommet (???)​
