What is this solenoid type thing?
Scode68
Noticed some fuel dripping from the top where the cap is when the chock is engaged. When I take the cap off there is a valve inside like a tire valve.
rabeck5792
Re: What is this solenoid type thing?
it is a primer solenoid,takes the place of choke butterflies.
Scode68
Valve is probably no good if fuel leaks out?
My thinking is if fuel leaks out then air will leak in.
tashasdaddy
Primer Solenoid
the primer replaced the old choke butterflies in the carborators, pushing in the key activates it, like the old choke plates. if for some reason you battery dies, and you have to rope start it, and need to choke the motor move the red lever, 180 degrees, once started move back to regular position.
there is a rebuild kit for the leaking area. out lined in yellow.
Scode68
Thanks, I?ll have to add that kit to my order also.
Could a problem with this cause bad idling and stall after warm up?
BigB9000
My vote is for maybe.
if its randomly putting gas into the cylinders, it'll run crappy, or if its sucking in air itlll run crappy too
